[Old/New] EZRun 150A-PRO V2 1/8 par Hobbywing Empty [Old/New] EZRun 150A-PRO V2 1/8 par Hobbywing
Dim 19 Juin 2011 - 20:11
par Hobbywing
[Old/New] EZRun 150A-PRO V2 1/8 par Hobbywing Ezrun150aproesc01
[Old/New] EZRun 150A-PRO V2 1/8 par Hobbywing Ezrun150aproesc02.th[Old/New] EZRun 150A-PRO V2 1/8 par Hobbywing Ezrun150aproesc03.th[Old/New] EZRun 150A-PRO V2 1/8 par Hobbywing Ezrun150aproesc04.th
Specification.
Model: EZRUN-150A PRO
Dimension: 68mm(L) x 55mm(W) x 45mm(H)
Cont. / Burst Current: 150A / 1080A
Resistance: 0.0002 ohm
Suitable Car: 1/5, 1/8 on-road and off-road cars / trucks for competitive race
Suitable Motor: =>3.5T
Battery: 6-18 cells (NiMH or NiCd) or 2-6 cells (Li-Po)
BEC Output: 5.75V/3A of Switch mode built-in BEC
Net Weght: 150g (without wires)
Features.
-Compatible with all sensorless brushless motors and most of sensored brushless motors such as Novak, LRP and Feigao Etc.
-Excellent start-up, acceleration and linearity features.
-3 running modes (Forward only with brake, Forward/Reverse with brake, Forward/Reverse immediately).
-4 steps of maximum reverse force adjustment.
-Proportional ABS brake function with 4 steps of maximum brake force adjustment, 8 steps of drag-brake force adjustment and 4 steps of initial brake force adjustment.
-9 start modes (Also called "Punch") from "very soft (Level 1)" to "very aggressive (Level 9)".
-Multiple protection features: Low voltage cut-off protection / Over-heat protection / Throttle signal loss protection / Motor blocked protection.
-8 steps of timing adjustment by software. You can even use this programmable item to adjust the timing value even for a sensored brushless motor. (Traditionally, you must turn the rear cover of the motor to change the timing value for a sensored brushless motor).
-Built-in switch mode BEC has a powerful output to supply all the electronic equipments.
-Firmware can be updated through an USB adapter (Optional equipment).
-Splash proof and dustproof.
Arrow Hobbywing
[Old/New] EZRun 150A-PRO V2 1/8 par Hobbywing Userba10
Victor01
Victor01
Nombre de messages : 793
[Old/New] EZRun 150A-PRO V2 1/8 par Hobbywing Empty Re: [Old/New] EZRun 150A-PRO V2 1/8 par Hobbywing
Dim 19 Juin 2011 - 20:56
y a quoi de nouveau comparé à l'ancien Question
Dim 19 Juin 2011 - 21:07
En composant, il faudrait explorer la question.
Sinon, c'est un EZ-Run V2 donc compatible avec le Boitier de programmation qui te permet aussi de paramétrer via ordinateur. (Comme le Castle Link)
Ven 1 Juil 2011 - 13:35
Alors personne pour le tester ? Very Happy
glop-pas-glop
Nombre de messages : 67
Ven 1 Juil 2011 - 22:04
Cà fait un moment que je lorgne sur ce contro et cherche des retours, mais rien trouvé de concret depuis que j'ai fumé mon MMM, environ 2-3 mois.
J'ai pris un Trackstar pour tester (et pour le prix ! ) mais vu les problèmes rencontrés par d'autres, je ne l'ai utilisé qu'en 4S.
Bref, l'EZRun Pro je viens de m'en commander un, parce que frustré de ne pouvoir sortir les 6S, mais pas encore reçu évidemment.
Attention quand même, vu les dimensions et le poids du bestiau, faut prévoir la place pour le loger.
Je verrai bien ce que çà donne, et je repasserai par ici pour dire quoi ! :cowboy:
Ven 1 Juil 2011 - 23:43
La v1 a eu des débuts plutôt difficiles, un peu comme les débuts du MMM mais elle fini par être stabilisé et amélioré, donc la v2 devrait le faire.
Je vais m'en prendre un aussi pour mon B-Slayer...Le Trackstar ira mon Summitz.
Tu vas l'installer sur quel Modèle/Config ?
glop-pas-glop
Sam 2 Juil 2011 - 7:47
Ben, j'avais prévu de le monter sur le E-Revo en 6S (MMM cramé) et le Trackstar que j'ai actuellement dessus devait aller sur la conversion de mon chassis 1/8 TT (en 4S), mais maintenant çà va dépendre du Trackstar après cette mésaventure (fonctionne t'il encore ? test aujourd'hui).
glop-pas-glop
Sam 2 Juil 2011 - 10:52
Bon ben vu que le Trackstar est dead, il me tarde de le recevoir ce EZ-Run Pro bounce
Sam 2 Juil 2011 - 17:28
Tu l'as commandé chez qui ?
Si tu as un lien, je suis preneur, merci.
Tu as pris aussi le boitier de programmation ?
glop-pas-glop
Sam 2 Juil 2011 - 19:31
Le contro ici
Le boitier de programmation LCD, pris sur HK, c'est moins cher :cowboy:
Mer 13 Juil 2011 - 17:40
Tu l'as reçu ?
glop-pas-glop
Jeu 14 Juil 2011 - 8:20
Le boitier de prog LCD est là, mais pas le contro Sad
Et je n'attends que lui pour remettre en route le E-Revo.
Après c'est parfois la loterie niveau délais depuis Hong-Kong, çà peut être là en 8-10 jours comme en 1 mois et demi, donc patience pale
Mais je m'occupe... Suis en train de me monter un 1/8 TT thermique :siffle:
Jeu 14 Juil 2011 - 13:10
Oui de plus avec le 14 Juillet et le pont...d'Avignon...ce n'est pas gagné.
Tiens-nous au jus.
glop-pas-glop
Mer 20 Juil 2011 - 21:06
Reçu aujourd'hui Very Happy
Première impression, c'est gros !
Un peu trop occupé pour m'en soucier maintenant, j'espère pouvoir faire le montage d'ici ce w-end.
Je ferais quelques photos Cool
Mer 20 Juil 2011 - 22:27
et 55,88mm(L) x 48,26mm(W) x 35,56mm(H) pour le MMMv3
Ça fait quand même une jolie petite différence.
glop-pas-glop
Dim 24 Juil 2011 - 8:31
Sauf qu'en réalité c'est plus du genre 76mm (L) x 52mm (W) x 46mm (H) affraid un beau bébé quoi !
On passe même à 79mm (L) si on compte la sortie des fils du contro, protégée par une petite protubérance de plastique.
En parlant de fil, celui à connecter au Rx est interminable : 45cm (pour info mon carrelage fait 33cm de côté)
[Old/New] EZRun 150A-PRO V2 1/8 par Hobbywing 1107240816071277298506860
Le contro est livré avec :
sa planche d'autocollant,
le manuel,
les câbles de raccordement au moteur (15cm, PK 6mm),
un câble supplémentaire (le rouge) pour pouvoir faire un câblage en série avec ceux qui vont vers l'accu (15cm également),
et les gaines thermo aux couleurs correspondantes ainsi qu'un p'ti bout de double face.
[Old/New] EZRun 150A-PRO V2 1/8 par Hobbywing 1107240816251277298506861
Je ne l'ai pas encore testé (pas câblé), j'attends de recevoir des prises EC5 que j'ai envie de tester également (marre des PK 5,5 qui se déconnectent à la réception des bosses prises trop violemment).
Et puis faut que je refasse les diffs du E-Revo Razz
Dim 24 Juil 2011 - 12:29
Ouch...Oui Sacré Bébé... Shocked
En tout cas, ils n'ont pas lésiné sur la longueur du câble ! Very Happy
Par contre, je n'ai jamais trouvé esthétiques tous ces câbles arc-en-ciel...
Tes PKs 5,5 se déconnectent ? Ce n'est pas normal, écarte un peu les "lames" de la prise male pour qu'elle soit plus serrée dans la prise femelle.
Ah oui, si tu n'aimes pas le bleu du corps des EC5 > tout simplement les teinter, avant de les monter bien sûr. Very Happy
glop-pas-glop
Dim 24 Juil 2011 - 16:29
Oui, et j'ai oublié de parler du poids : 190g seul ou près de 240g avec les câbles moteur :respect:
Tu vois qu'au final on est assez éloigné des specs techniques annoncées... scratch
Pour les PK, écarter les "lames" des prises males, je l'ai déjà fait.
Cà améliore la tenue, mais çà fini toujours par se resserrer de nouveau au fil des connections/déconnections.
J'ai juste envie de tester autre chose...
Pour le bleu de la prise, çà ne me pose pas de problème.
Victor01
Victor01
Dim 24 Juil 2011 - 16:40
il faut les chauffer et après tu écarte les lamelles
elles garde la forme plus longtemps Wink
sympa ce contro Very Happy
Dim 24 Juil 2011 - 17:00
tu a des PK 5.5 chinoise non ??
si oui cherche pas plus loin, de la vrais guimove
Dim 24 Juil 2011 - 17:30
@Glop-pas-glop
Oui assez loin même...Il ne veulent pas faire peur. Laughing
J'achète mes 8mm chez HB et je n'ai jamais eu de problème et pourtant plus made in china qu'eux, c'est difficile.
...quoique sur ebay, il y vraiment parfois du n'importe quoi...
glop-pas-glop
Dim 24 Juil 2011 - 19:06
Chezoit a écrit:@Glop-pas-glop
:mdr1:
Je ferais une photo une fois installé sur le E-Revo. Je l'ai mis comme çà juste pour voir, et il remplit bien le volume alloué à l'ESC. Il faudra lui bricoler une fixation aussi...
Gilou a écrit:tu a des PK 5.5 chinoise non ??
Les chinoiseries PK 5,5 çà va au début, ce n'est pas de la grosse qualité niveau finition, mais surtout çà vieillit assez mal.
Et effectivement çà se rapproche de la guimauve maintenant :lol2:
victor01 a écrit:il faut les chauffer et après tu écarte les lamelles
Je ne veux plus m'embêter avec çà Wink , je change tout !
Dim 24 Juil 2011 - 19:12
Tiens d'ailleurs, je pensais au support pour le EZR V2, tu as une idée ?
Il y a quelques choses sous le contro ? Rail/trous/... ?
Mario
Mario
Nombre de messages : 595
Ven 29 Juil 2011 - 11:32
ce contro et il compatible avec un moteur xerun 2000kv/2250kv
Ven 29 Juil 2011 - 18:57
Features.
Comme noté, compatible avec la plus par des moteurs Sensored mais n'a pas de capteur.
Oui d'ailleurs tes moteurs sont les versions Sensored ou Sensorless ?
Tu as eu un problème avec ton Xerun 150A ?
